跳转到主内容
Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement
你所需要的
  1. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Earmuff: 步骤 1 中的图像 1,1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: 步骤 2 中的图像 1,1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: 步骤 3 中的图像 1,2 Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: 步骤 3 中的图像 2,2
    • After removing the muffs, the speaker cover must be removed by unscrewing 4 3mm Phillips screws using a #000 Phillips screwdriver.
  4. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: 步骤 4 中的图像 1,1
    • After locating the circuit board that contains the charging port as well as the volume control dial, two 3 mm screws must be removed using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: 步骤 5 中的图像 1,1
    • Unplug the blue ribbon attaching the circuit board to the motherboard.
结论
另外一个人完成了本指南。
2条评论
where do I get the replacement module?
Jan G - 回复
Have you found one yet? I've needed to do this repair for a while.
Paul B -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 47
总计 432
