简介
This guide will walk you through safely removing the battery and outer case of the Sega Saturn, either for replacing the case or gaining access to other internal parts. If your case is physically damaged, you can use this guide to completely replace the outer case. However, if you find your case is structurally sound but has yellowed or become discolored, you can remove the case and clean it chemically to restore it’s original color.
你所需要的
Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
另外一个人完成了本指南。
