跳转到主内容
加入维修社区 - 创建账户
Sega Master System Model 2 Disassembly
你所需要的
视频概述
  1. Sega Master System Model 2 Disassembly, The Case: 步骤 1 中的图像 1,1
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: 步骤 2 中的图像 1,1
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: 步骤 3 中的图像 1,1
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: 步骤 4 中的图像 1,1
    • Congratulations! You have opened your Sega Master System Model 2!
结论
Screenshots taken from a video by Global Garage
3等其他人完成本指南。
Krisander 1998
于10/18/17注册
668 声望
创作了2篇指南
3指南评论
This is in the wrong section.
Owen Ready - 回复
Nope, its in the Sega Master System area.
Krisander 1998 -
Not a Master System
Chad Luciano - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 70
总计 3,297
