跳转到主内容
Sega Genesis Power LED Replacement
你所需要的
  1. Sega Genesis Power LED Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Power LED Replacement: 步骤 2 中的图像 1,1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Power LED Replacement: 步骤 3 中的图像 1,1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Power LED Replacement: 步骤 4 中的图像 1,1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Power LED Replacement: 步骤 5 中的图像 1,1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Power LED Replacement: 步骤 6 中的图像 1,1
    • Separate the main board from the outer case.
  7. Sega Genesis Power LED Replacement, Power LED: 步骤 7 中的图像 1,1
    • Remove plastic "Power / On" cover by pushing tabs together.
  8. Sega Genesis Power LED Replacement: 步骤 8 中的图像 1,1
    • Pull "Power / On" cover away from the console cover.
  9. Sega Genesis Power LED Replacement: 步骤 9 中的图像 1,1
    • From the outside of the top cover, remove LED.
  10. Sega Genesis Power LED Replacement: 步骤 10 中的图像 1,1
  11. Sega Genesis Power LED Replacement: 步骤 11 中的图像 1,1
    • Re-insert "Power / On" cover until it clicks into place.
结论
5等其他人完成本指南。
团队
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G29
4 名成员
创作了14篇指南
4条评论
My LED won't turn on when I turn on the machine though when I took it out and touched it on a battery it lit up. Did I put it back in wrong or what?
Brandon - 回复
Long leg on the LED goes to the red wire.
Short leg to the white wire. If that's not the case, you may have burned the LED or the spot doesn't work anymore.
Last attempt would be getting your +V5 from the resistor below as shown in this image.
http://i.imgur.com/TucGEXj.jpg
Thunder....16
PIero Bogani -
The model I am trying to change the led on is the 1601 HD graphics Genesis. The problem I have is there are NO simple easy press tabs to pop off the red ring. What is the correct way to remove the LED on this model? Thank you for your time.
snoopydaturd - 回复
Hey snoopy don't give up hope I made a video on how to fix your problem check out this video
https://youtu.be/HJPyhfy56a0
thebigtoe_98 -
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 51
过去 30 天: 140
总计 18,287
