跳转到主内容
简介
This guide will help you remove the batteries in your controller. This is a relatively simple guide, and you’ll only need a Phillips #000 screwdriver to complete the process.
  1. Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: 步骤 1 中的图像 1,2 Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: 步骤 1 中的图像 2,2
    • Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
    • The screw does not detach from the battery cover, so do not attempt to separate them.
  2. Sega Genesis Flashback Controller Batteries Replacement: 步骤 2 中的图像 1,2 Sega Genesis Flashback Controller Batteries Replacement: 步骤 2 中的图像 2,2
    • If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
    • Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
    • All AAA batteries have “+” and “-” symbols on each end of the batteries to denote the positive and negative ends.
结论
2等其他人完成本指南。
Omar Shorab
于2018年04月23日注册
261 声望
创作了2篇指南
团队
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G12
4 名成员
创作了10篇指南
一条评论
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
Scott Phaneuf - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 38
总计 2,142
