跳转到主内容
Sega Genesis 6 button controller
你所需要的
  1. Sega Genesis 6 button controller, Disassembling the handle: 步骤 1 中的图像 1,1
    • Flip the controller upside down.
    • Using a Phillips #00 screwdriver, remove the five screws holding the controller back cover in place.
  2. Sega Genesis 6 button controller: 步骤 2 中的图像 1,1
    • Then remove the back cover of the controller, which gives you access to the motherboard of the controller.
    • Carefully put back the 5 screws from step 1 as well as the back cover of the controller
  3. Sega Genesis 6 button controller, Disassembling the motherboard: 步骤 3 中的图像 1,2 Sega Genesis 6 button controller, Disassembling the motherboard: 步骤 3 中的图像 2,2
    • Remove the motherboard from the controller body, after releasing the rubber part that holds the cable in the controller body
    • This gives you access to the button contact pads
  4. Sega Genesis 6 button controller, Dismantling the buttons: 步骤 4 中的图像 1,1
    • Remove the contact pads
    • Then remove the 8 plastic buttons
  5. Sega Genesis 6 button controller, Dismantling the Directional Pad: 步骤 5 中的图像 1,3 Sega Genesis 6 button controller, Dismantling the Directional Pad: 步骤 5 中的图像 2,3 Sega Genesis 6 button controller, Dismantling the Directional Pad: 步骤 5 中的图像 3,3
    • In order to disassemble the directional cross, it is necessary to levergentlypreferably with a plastic Spudger, under the 4 retaining tabs.
    • Then, push in the central hole with a fine tool (here a screwdriver), in order to undo the assembly
    • For reassembly, be careful to put the corrector in front of the slot of the outer part!
结论
Follow these steps in reverse order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
fr en
100%
tayola正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 57
总计 2,056
