跳转到主内容
Sega Game Gear Headphone Jack/Volume Wheel Replacement
你所需要的
  1. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 2 中的图像 1,1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Case: 步骤 3 中的图像 1,1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 4 中的图像 1,1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 5 中的图像 1,2 Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 5 中的图像 2,2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 6 中的图像 1,3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 6 中的图像 2,3 Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 6 中的图像 3,3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: 步骤 7 中的图像 1,2 Sega Game Gear Headphone Jack/Volume Wheel Replacement, Headphone Jack/Volume Wheel: 步骤 7 中的图像 2,2
    • Unscrew the screws to remove the metal covering.
  8. Sega Game Gear Headphone Jack/Volume Wheel Replacement: 步骤 8 中的图像 1,1
    • The screws that need to be removed are missing from this picture.
    • Remove the two screws from the highlighted locations.
结论
Brandon Page
于04/15/10注册
179 声望
创作了2篇指南
团队
Cal Poly, Team 28-33, Regan Spring 2010 Cal Poly, Team 28-33, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G33
5 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 6,799
