跳转到主内容
Sega Dreamcast Top Cover Replacement
你所需要的
  1. Sega Dreamcast Top Cover Replacement, Expansion Bay: 步骤 1 中的图像 1,2 Sega Dreamcast Top Cover Replacement, Expansion Bay: 步骤 1 中的图像 2,2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Top Cover Replacement: 步骤 2 中的图像 1,3 Sega Dreamcast Top Cover Replacement: 步骤 2 中的图像 2,3 Sega Dreamcast Top Cover Replacement: 步骤 2 中的图像 3,3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Top Cover Replacement, Top Cover: 步骤 3 中的图像 1,1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Top Cover Replacement: 步骤 4 中的图像 1,1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
结论
6等其他人完成本指南。
wkwong
于11/14/09注册
492 声望
创作了5篇指南
团队
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 的会员
CPSU-REGAN-F09S5G1
5 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 11,593
