跳转到主内容
Sega Dreamcast Logic Board Replacement
你所需要的
  1. Sega Dreamcast Logic Board Replacement, Expansion Bay: 步骤 1 中的图像 1,2 Sega Dreamcast Logic Board Replacement, Expansion Bay: 步骤 1 中的图像 2,2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Logic Board Replacement: 步骤 2 中的图像 1,3 Sega Dreamcast Logic Board Replacement: 步骤 2 中的图像 2,3 Sega Dreamcast Logic Board Replacement: 步骤 2 中的图像 3,3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Logic Board Replacement, Top Cover: 步骤 3 中的图像 1,1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Logic Board Replacement: 步骤 4 中的图像 1,1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): 步骤 5 中的图像 1,2 Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): 步骤 5 中的图像 2,2
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  6. Sega Dreamcast Logic Board Replacement: 步骤 6 中的图像 1,1
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  7. Sega Dreamcast Logic Board Replacement: 步骤 7 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 7 中的图像 2,2
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  8. Sega Dreamcast Logic Board Replacement: 步骤 8 中的图像 1,1
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
  9. Sega Dreamcast Logic Board Replacement, Controller Port: 步骤 9 中的图像 1,2 Sega Dreamcast Logic Board Replacement, Controller Port: 步骤 9 中的图像 2,2
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  10. Sega Dreamcast Logic Board Replacement: 步骤 10 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 10 中的图像 2,2
    • Remove the four 14mm Philips #02 screws located on the controller board.
  11. Sega Dreamcast Logic Board Replacement: 步骤 11 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 11 中的图像 2,2
    • Disconnect the white fan header from the controller port.
  12. Sega Dreamcast Logic Board Replacement: 步骤 12 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 12 中的图像 2,2
    • Remove the controller board by lifting it up from the controller port.
  13. Sega Dreamcast Logic Board Replacement, GD-ROM: 步骤 13 中的图像 1,2 Sega Dreamcast Logic Board Replacement, GD-ROM: 步骤 13 中的图像 2,2
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  14. Sega Dreamcast Logic Board Replacement: 步骤 14 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 14 中的图像 2,2
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  15. Sega Dreamcast Logic Board Replacement: 步骤 15 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 15 中的图像 2,2
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  16. Sega Dreamcast Logic Board Replacement: 步骤 16 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 16 中的图像 2,2
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  17. Sega Dreamcast Logic Board Replacement, Fan: 步骤 17 中的图像 1,1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  18. Sega Dreamcast Logic Board Replacement: 步骤 18 中的图像 1,1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  19. Sega Dreamcast Logic Board Replacement: 步骤 19 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 19 中的图像 2,2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  20. Sega Dreamcast Logic Board Replacement, Logic Board: 步骤 20 中的图像 1,3 Sega Dreamcast Logic Board Replacement, Logic Board: 步骤 20 中的图像 2,3 Sega Dreamcast Logic Board Replacement, Logic Board: 步骤 20 中的图像 3,3
    • Remove the five 10mm Philips #02 screws from left side of the logic board cover.
    • Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
  21. Sega Dreamcast Logic Board Replacement: 步骤 21 中的图像 1,3 Sega Dreamcast Logic Board Replacement: 步骤 21 中的图像 2,3 Sega Dreamcast Logic Board Replacement: 步骤 21 中的图像 3,3
    • Lift the metal cover from the console.
  22. Sega Dreamcast Logic Board Replacement: 步骤 22 中的图像 1,2 Sega Dreamcast Logic Board Replacement: 步骤 22 中的图像 2,2
    • Before handing the logic board, you may want to use a grounding strap to protect the device from static charge. If you do not have a grounding strip, you may ground yourself by touching a large metallic object.
    • Remove the logic board and set the logic board on an anti-static surface.
结论
23等其他人完成本指南。
wkwong
于11/14/09注册
557 声望
创作了5篇指南
团队
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 的会员
CPSU-REGAN-F09S5G1
5 名成员
创作了21篇指南
1指南评论
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
Nickolas Wilcox - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 40
过去 30 天: 226
总计 26,810
