跳转到主内容
Sega Dreamcast GD-ROM Replacement
你所需要的
  1. Sega Dreamcast GD-ROM Replacement, Expansion Bay: 步骤 1 中的图像 1,2 Sega Dreamcast GD-ROM Replacement, Expansion Bay: 步骤 1 中的图像 2,2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast GD-ROM Replacement: 步骤 2 中的图像 1,3 Sega Dreamcast GD-ROM Replacement: 步骤 2 中的图像 2,3 Sega Dreamcast GD-ROM Replacement: 步骤 2 中的图像 3,3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast GD-ROM Replacement, Top Cover: 步骤 3 中的图像 1,1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast GD-ROM Replacement: 步骤 4 中的图像 1,1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast GD-ROM Replacement, GD-ROM: 步骤 5 中的图像 1,2 Sega Dreamcast GD-ROM Replacement, GD-ROM: 步骤 5 中的图像 2,2
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  6. Sega Dreamcast GD-ROM Replacement: 步骤 6 中的图像 1,2 Sega Dreamcast GD-ROM Replacement: 步骤 6 中的图像 2,2
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  7. Sega Dreamcast GD-ROM Replacement: 步骤 7 中的图像 1,2 Sega Dreamcast GD-ROM Replacement: 步骤 7 中的图像 2,2
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  8. Sega Dreamcast GD-ROM Replacement: 步骤 8 中的图像 1,2 Sega Dreamcast GD-ROM Replacement: 步骤 8 中的图像 2,2
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  9. Sega Dreamcast GD-ROM Replacement, GD-ROM: 步骤 9 中的图像 1,2 Sega Dreamcast GD-ROM Replacement, GD-ROM: 步骤 9 中的图像 2,2
    • Replace the bad GD-ROM drive with a functional one.
  10. Sega Dreamcast GD-ROM Replacement: 步骤 10 中的图像 1,2 Sega Dreamcast GD-ROM Replacement: 步骤 10 中的图像 2,2
    • Secure the new GD-ROM drive to the console with the Philips #2 screws.
  11. Sega Dreamcast GD-ROM Replacement: 步骤 11 中的图像 1,3 Sega Dreamcast GD-ROM Replacement: 步骤 11 中的图像 2,3 Sega Dreamcast GD-ROM Replacement: 步骤 11 中的图像 3,3
    • Connect the three GD-ROM cables to the logic board.
    • Connect the GD-ROM data ribbon to the logic board.
终点
10等其他人完成本指南。
Thorr686
于11/06/09注册
500 声望
创作了2篇指南
团队
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 的会员
CPSU-REGAN-F09S5G1
5 名成员
创作了21篇指南
2指南评论
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
Anthony Salmon - 回复
My HKT-3020 console, NTSC-U revision 1, manufactured in Japan during 4/2000, does not have the orange cable shown in step 5. I was able to skip steps 5 and 6, and for step 7 I had to remove 3 screws, not 2. My GD-ROM drive came as an assembly, mounted on a metal plate; the entire assembly simply lowers into a connector port. After removing the screws, I just had to gently wiggle it up and out of the port, then lower the replacement assembly into the same port, and replace the 3 screws.
Aaron Teplitsky - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 80
过去 30 天: 255
总计 36,998
