当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Verify that the console is disconnected from the AC outlet before you begin.
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Internal components can be loose. Be careful that they do not fall out when removing the cover.
Turn the console right side up.
Remove the top cover by gently lifting the upper portion of the console.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
