简介
A guide to remove the intake fan from the Sega Dreamcast.
Verify that the console is disconnected from the AC outlet before you begin.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
添加评论
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
添加评论
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
添加评论
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
添加评论
  • Remove the white fan header by gently pulling it away from from the controller port.
  • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
添加评论
  • Remove the two 8.5mm Philips #00 screws from the fan bracket.
添加评论
  • Remove the two 17.5mm Philips #00 screws from the fan bracket.
  • Remove the fan from the bracket.
添加评论
结论
2等其他人完成本指南。
wkwong
于2009年11月14日注册
414 信誉积分
创作了7篇指南
团队
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 的会员
CPSU-REGAN-F09S5G1
5 名成员
创作了23篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 4
过去的30天: 11
总计 6,075
