跳转到主内容
Sega CD Plastic Housing Removal
你所需要的
  1. Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: 步骤 1 中的图像 1,2 Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: 步骤 1 中的图像 2,2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Plastic Housing Removal: 步骤 2 中的图像 1,1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Plastic Housing Removal: 步骤 3 中的图像 1,1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Plastic Housing Removal: 步骤 4 中的图像 1,1
    • Lift from the left side to remove the top of the case.
  5. Sega CD Plastic Housing Removal: 步骤 5 中的图像 1,1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Plastic Housing Removal: 步骤 6 中的图像 1,1
    • Lift the top of the case to remove the cover.
  7. Sega CD Plastic Housing Removal: 步骤 7 中的图像 1,1
    • Remove the faceplate by pulling it up, then out.
结论
To reassemble the device, follow these instructions in reverse order.
另外一个人完成了本指南。
Ryan Kotzebue
于10/07/10注册
271 声望
创作了4篇指南
团队
Cal Poly, Team 5-14, Maness Fall 2010 Cal Poly, Team 5-14, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G14
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 4,881
