当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Using a Phillips head screwdriver remove six screws from the bottom of the console.
The six screws are marked.
Remove the two screws that attach the Genesis' connector to the rest of the console.
The two screws are marked in the diagram.
Slide the lock tab to the left to separate the halves of the console.
Lift from the left side to remove the top of the case.
Using the spudger, pry the cover off of the Genesis attachment.
Lift the top of the case to remove the cover.
Remove the faceplate by pulling it up, then out.
Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
The three screws are shown on the diagram.
Remove the two screws from the plastic bar.
The two screws are shown pictured.
To remove the CD tray
Remove the four screws with the Phillips head screwdriver.
Carefully unplug the wire connected to optical reader.
Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
The four screws are highlighted on the diagram.
The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
Carefully remove the CD tray from circuit board.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与9其他贡献者
于10/18/10注册
21 声望
创作了2篇指南
徽章: 5
+ 2更多徽章
CPSU-MANESS-F10S5G14
4 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 7
过去 7 天: 20
过去 30 天: 46
总计 9,609
