跳转到主内容
加入维修社区 - 创建账户
Sega CD CD Tray Replacement
你所需要的
  1. Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: 步骤 1 中的图像 1,2 Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: 步骤 1 中的图像 2,2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD CD Tray Replacement: 步骤 2 中的图像 1,1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD CD Tray Replacement: 步骤 3 中的图像 1,1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD CD Tray Replacement: 步骤 4 中的图像 1,1
    • Lift from the left side to remove the top of the case.
  5. Sega CD CD Tray Replacement: 步骤 5 中的图像 1,1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD CD Tray Replacement: 步骤 6 中的图像 1,1
    • Lift the top of the case to remove the cover.
  7. Sega CD CD Tray Replacement: 步骤 7 中的图像 1,1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD CD Tray Replacement, CD Tray: 步骤 8 中的图像 1,2 Sega CD CD Tray Replacement, CD Tray: 步骤 8 中的图像 2,2
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Sega CD CD Tray Replacement: 步骤 9 中的图像 1,2 Sega CD CD Tray Replacement: 步骤 9 中的图像 2,2
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. Sega CD CD Tray Replacement: 步骤 10 中的图像 1,2 Sega CD CD Tray Replacement: 步骤 10 中的图像 2,2
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Sega CD CD Tray Replacement: 步骤 11 中的图像 1,1
    • Carefully unplug the wire connected to optical reader.
  12. Sega CD CD Tray Replacement: 步骤 12 中的图像 1,2 Sega CD CD Tray Replacement: 步骤 12 中的图像 2,2
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Sega CD CD Tray Replacement: 步骤 13 中的图像 1,1
    • Carefully remove the CD tray from circuit board.
结论
2等其他人完成本指南。
sskyllin
于10/18/10注册
27 声望
创作了2篇指南
团队
Cal Poly, Team 5-14, Maness Fall 2010 Cal Poly, Team 5-14, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G14
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 66
总计 10,710
