跳转到主内容
Sears Craftsman 315.109020 Motor Replacement
你所需要的
  1. Sears Craftsman 315.109020 Motor Replacement, Motor: 步骤 1 中的图像 1,2 Sears Craftsman 315.109020 Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • To ensure that you do not get grease and dirt on your table or floor, lay a towel down before you begin working.
    • The grease from the circular saw can stain your towel so a dirty towel or work rag is recommended.
  2. Sears Craftsman 315.109020 Motor Replacement: 步骤 2 中的图像 1,3 Sears Craftsman 315.109020 Motor Replacement: 步骤 2 中的图像 2,3 Sears Craftsman 315.109020 Motor Replacement: 步骤 2 中的图像 3,3
    • With your Phillips screwdriver, unscrew all 7 of the 20 mm screws on the handle of the circular saw.
    • There is one 25 mm screw that goes in the hole circled in red.
    • Unscrew the forked screw head
    • Lift off the top half of the handle.
  3. Sears Craftsman 315.109020 Motor Replacement: 步骤 3 中的图像 1,2 Sears Craftsman 315.109020 Motor Replacement: 步骤 3 中的图像 2,2
    • Unscrew the two wide-head 20 mm screws holding the remaining half of the handle to the motor.
    • Remove the remaining half of the handle from the motor by lifting it over the screw that is keeping it in place.
  4. Sears Craftsman 315.109020 Motor Replacement: 步骤 4 中的图像 1,3 Sears Craftsman 315.109020 Motor Replacement: 步骤 4 中的图像 2,3 Sears Craftsman 315.109020 Motor Replacement: 步骤 4 中的图像 3,3
    • Using a crescent wrench, unscrew the hex washer head screw that is holding the blade in place.
    • Lift the blade over the internally threaded screw and pull it off of the saw.
    • If the hex washer head screw rotates but does not loosen or if the whole blade rotates as you turn your wrench, giving the wrench a quick jerk should loosen the screw.
  5. Sears Craftsman 315.109020 Motor Replacement: 步骤 5 中的图像 1,2 Sears Craftsman 315.109020 Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the blade cover by applying upward pressure until it unsnaps from the washer.
    • The blade cover will come off easier if it is facing away from the rest of the saw (see second picture).
  6. Sears Craftsman 315.109020 Motor Replacement: 步骤 6 中的图像 1,2 Sears Craftsman 315.109020 Motor Replacement: 步骤 6 中的图像 2,2
    • Unscrew the 70 mm screw that is inside the black tube (see first picture).
    • Unscrew the five screws as highlighted in the second picture. The bottom left is a 70 mm screw and the other four are 20 mm screws.
    • Unscrewing the remaining four 20 mm screws are unnecessary unless you wish to repair or replace the cogs in the saw.
  7. Sears Craftsman 315.109020 Motor Replacement: 步骤 7 中的图像 1,2 Sears Craftsman 315.109020 Motor Replacement: 步骤 7 中的图像 2,2
    • The motor will now be loose and you should be able to twist the motor in a counter-clockwise direction until it is able to be pulled off.
结论
另外一个人完成了本指南。
Blake Avant
于09/29/15注册
218 声望
创作了2篇指南
团队
Cal Poly, Team 17-4, Green Fall 2015 Cal Poly, Team 17-4, Green Fall 2015 的会员
CPSU-GREEN-F15S17G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 380
