跳转到主内容
Sears Craftsman 315.109020 Blade/ Blade Cover Replacement
你所需要的
  1. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: 步骤 1 中的图像 1,2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: 步骤 1 中的图像 2,2
    • Although this is not a difficult fix, it can definitely make a mess.
    • Lay down a dirty towel or work rag and place the saw on top of the towel.
    • Handle the saw with care and avoid placing your hands on or near the blade when possible.
  2. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 步骤 2 中的图像 1,3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 步骤 2 中的图像 2,3 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 步骤 2 中的图像 3,3
    • Use the crescent wrench to remove the hex washer head screw and the washer.
    • Gently lift the blade up and pull it off of the internal threaded shaft.
    • If the hex washer head screw, or the entire blade spins as you turn the wrench, a quick jerk of the crescent wrench should loosen the screw.
    • Although many screws loosen in the clockwise direction, the hex washer head screw on this circular saw loosens in the counter-clockwise direction.
  3. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 步骤 3 中的图像 1,2 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: 步骤 3 中的图像 2,2
    • Lift up on the blade cover until it unsnaps from the washer.
    • The blade cover will come off easier if the bulk of the cover is facing away from the saw.
结论
Blake Avant
于09/29/15注册
218 声望
创作了2篇指南
团队
Cal Poly, Team 17-4, Green Fall 2015 Cal Poly, Team 17-4, Green Fall 2015 的会员
CPSU-GREEN-F15S17G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 999
