跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的External Storage,请使用我们的维修手册
  1. Seagate 3TB Expansion Desktop Drive Teardown, Seagate 3TB Expansion Desktop Drive Teardown: 步骤 1 中的图像 1,1
    • Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Once you have the end opened up, use the credit card to hold it open.
    • When you have the entire end separated, carefully pry the sides out and away along the adjoining two sides, working your way towards the end with the power jack. Save that end for last, it should lift away when you're done with the other sides.
  2. Seagate 3TB Expansion Desktop Drive Teardown: 步骤 2 中的图像 1,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 2 中的图像 2,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 2 中的图像 3,3
    • Work around the drive, ends first then the sides to open it
    • This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
  3. Seagate 3TB Expansion Desktop Drive Teardown: 步骤 3 中的图像 1,1
    • Gently pull the sides slightly and the drive will lift out
  4. Seagate 3TB Expansion Desktop Drive Teardown: 步骤 4 中的图像 1,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 4 中的图像 2,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 4 中的图像 3,3
    • Pull the rubber screw covers off, these are mounted with a little glue and came off easily
    • Remove all four screws with the philips screwdriver
  5. Seagate 3TB Expansion Desktop Drive Teardown: 步骤 5 中的图像 1,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 5 中的图像 2,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 5 中的图像 3,3
    • Slide drive out of metal caddy (do not lift)
    • You will now have a SATA Hard Drive and the caddy separate
  6. Seagate 3TB Expansion Desktop Drive Teardown: 步骤 6 中的图像 1,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 6 中的图像 2,3 Seagate 3TB Expansion Desktop Drive Teardown: 步骤 6 中的图像 3,3
    • From the bottom of the caddy there are two black screws
    • With the Philips screwdriver you can remove these
    • Pull the circuit board gently and evenly to remove it
Edd
于04/08/13注册
535 声望
创作了2篇指南
3条评论
if i add a different adapter that doesnt require power, will the drive still work?
sulz - 回复
Does anyone know what to do if the Data port does not work ?
remus lungeanu - 回复
Thanks... I probably broke every clip in the process, but I finally got it apart... Tested the drive in another external USB case and still can't see the drive, so my hope that it was the case circuitry that was bad was crushed... 3TB paperweight... Thanks Seagate :(
Sean Seoltoir - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 321
过去 30 天: 388
总计 55,520
