跳转到主内容
Sony Dream Machine ICF-C717PJ Screen Replacement
你所需要的
  1. Sony Dream Machine ICF-C717PJ Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Using a Phillips #0 screwdriver unscrew the three screws that connect the back panel to the device.
  2. Sony Dream Machine ICF-C717PJ Screen Replacement: 步骤 2 中的图像 1,1
    • Using a thin flat tool, pry off the panel on the back of the device.
  3. Sony Dream Machine ICF-C717PJ Screen Replacement: 步骤 3 中的图像 1,2 Sony Dream Machine ICF-C717PJ Screen Replacement: 步骤 3 中的图像 2,2
    • Unscrew the two screws connecting the motor board to the device.
    • Gently remove the motherboard from the device to gain access to the screen.
  4. Sony Dream Machine ICF-C717PJ Screen Replacement: 步骤 4 中的图像 1,2 Sony Dream Machine ICF-C717PJ Screen Replacement: 步骤 4 中的图像 2,2
    • Flip the device around so that the display is facing you. Gently push the display towards the inside of the device.
    • Disconnect the display cable from the motherboard and reconnect the display cable for the new display.
    • After connecting the new display push it firmly in place so that the display panel is properly aligned with the cutout for the display. When correctly locked in place the display panel should not move around.
结论
Gurleen Powar
于08/11/18注册
376 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G3, Liner Summer 2018 UW Tacoma, Team S1-G3, Liner Summer 2018 的会员
UWT-LINER-SU18S1G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,049
