跳转到主内容
Screen Door Closer Replacement
你所需要的
  1. Screen Door Closer Replacement, Door closer: 步骤 1 中的图像 1,1
    • Make sure the door is completely closed. push up from the bottom to remove the pin from the bracket that connects the barrel to the door frame and release the door closer barrel.
    • If the pin is under too much tension, open the door about an inch and slide the open clip (metal washer that keeps the screen door open) against the barrel and repeat step 1.
  2. Screen Door Closer Replacement: 步骤 2 中的图像 1,1
    • After removing the pin, the closer barrel can be removed.
  3. Screen Door Closer Replacement: 步骤 3 中的图像 1,1
    • Loosen the screws from the bracket on the screen door to remove the bracket.
  4. Screen Door Closer Replacement: 步骤 4 中的图像 1,1
    • Loosen the screws from the door jamb bracket and remove.
  5. Screen Door Closer Replacement: 步骤 5 中的图像 1,1
    • Attach the new bracket to the door jamb with provided screws.
  6. Screen Door Closer Replacement: 步骤 6 中的图像 1,1
    • Slide the new clip (metal washer that was provided with the door closer) on the door closer barrel with the dented side facing inwards (as shown in photo).
  7. Screen Door Closer Replacement: 步骤 7 中的图像 1,1
    • Insert the pin into the closer barrel and the jamb bracket.
  8. Screen Door Closer Replacement: 步骤 8 中的图像 1,1
    • Install new bracket onto screen door. Keep screws slightly loose.
  9. Screen Door Closer Replacement: 步骤 9 中的图像 1,1
    • Slip the other pin into the barrel and the bracket.
  10. Screen Door Closer Replacement: 步骤 10 中的图像 1,1
    • Slide the bracket away from the barrel until there is no slack. Tighten screws on the bracket.
  11. Screen Door Closer Replacement: 步骤 11 中的图像 1,1
    • Test the door and if there are any issues (i.e. door closing too fast or too slow). Make necessary adjustments to the tension screw.
结论
2等其他人完成本指南。
Shafaq Hasan
于10/26/17注册
122 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 100
总计 9,798
