跳转到主内容
Schwinn Tourist Inner Tube Replacement
你所需要的
  1. Schwinn Tourist Inner Tube Replacement, Front Inner Tube: 步骤 1 中的图像 1,1
    • Flip the bicycle upside down.
    • By flipping the bicycle upside down it will offer additional support by being able to stand up by itself.
  2. Schwinn Tourist Inner Tube Replacement, Loosen The Brakes: 步骤 2 中的图像 1,1
    • Apply pressure to both sides of the brake arm with one hand and lift the metal brake cable from the brake caliper.
    • By releasing the brake cable from the brake caliper, it will loosen the brake pads by the tire.
  3. Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: 步骤 3 中的图像 1,2 Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: 步骤 3 中的图像 2,2
    • Push the quick release lever outwards towards your body.
    • While holding the other end of the quick release lever, rotate the lever counter-clockwise until it is loose.
  4. Schwinn Tourist Inner Tube Replacement, Remove Tire: 步骤 4 中的图像 1,1
    • Lift the tire to remove it from the bicycle.
  5. Schwinn Tourist Inner Tube Replacement, Inserting The Tire Lever: 步骤 5 中的图像 1,1
    • Insert the flat end of the tire lever between the inside wall of the tire and the outside of the rim.
    • Attach the other end of the tire lever to the nearest spoke on the rim.
  6. Schwinn Tourist Inner Tube Replacement, Insering Second Tire Lever: 步骤 6 中的图像 1,1
    • Insert a second tire lever next to the first lever to create leverage for releasing the tire from the rim.
  7. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: 步骤 7 中的图像 1,1
    • Leave the first lever in place. Slide the second lever against the outside edge of the rim until one side of the tire is off of the rim.
  8. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: 步骤 8 中的图像 1,1
    • Reattach the the first lever to the other side of the tire and repeat steps 4-7 to remove tire completely from rim.
  9. Schwinn Tourist Inner Tube Replacement, Remove the Valve Stem: 步骤 9 中的图像 1,1
    • Push the valve stem upwards through the hole in the rim.
  10. Schwinn Tourist Inner Tube Replacement, Finished: 步骤 10 中的图像 1,1
    • Once valve stem is pushed, pull the inner tube until it is completely removed from the rim.
结论
另外一个人完成了本指南。
Quandre Mebane
于10/07/14注册
149 声望
撰写一个指南
团队
USF Tampa, Team 1-22, Donnelly Fall 2014 USF Tampa, Team 1-22, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G22
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 5,170
