跳转到主内容
Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement
你所需要的
  1. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement, Training Wheels: 步骤 1 中的图像 1,1
    • Flip the bike upside-down for stability.
  2. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: 步骤 2 中的图像 1,3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: 步骤 2 中的图像 2,3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: 步骤 2 中的图像 3,3
    • Use a 15mm socket wrench, and remove the wheel arm bolt securing the wheel arm.
    • Remove the damaged wheel arm.
  3. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: 步骤 3 中的图像 1,3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: 步骤 3 中的图像 2,3 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: 步骤 3 中的图像 3,3
    • To replace a damaged wheel, use a 13 mm socket and a Phillips screwdriver, and remove the wheel screw fastening the wheel to the wheel arm.
    • The screw may be hidden behind the bike's design theme. If this is the case, poke through the label to reach the screw in the center of the wheel.
    • Replace the damaged wheel and secure it with the screw you just removed from the old wheel.
  4. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: 步骤 4 中的图像 1,1
    • Realign the wheel arm with the rear bolt placement and secure it with the wheel arm bolt.
    • Replace the damaged wheel arm prior to securing it in place.
结论
Brian Gibson
于05/24/23注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 92
