跳转到主内容
Sceptre X9 Komodo VII Power Supply Unit Replacement
你所需要的
  1. Sceptre X9 Komodo VII Power Supply Unit Replacement, Stand: 步骤 1 中的图像 1,1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 2 中的图像 1,1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Power Supply Unit Replacement, Board Cover: 步骤 3 中的图像 1,1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 4 中的图像 1,3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 4 中的图像 2,3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 4 中的图像 3,3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 5 中的图像 1,2 Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 5 中的图像 2,2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Power Supply Unit Replacement, Power Supply Unit: 步骤 6 中的图像 1,1
    • Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
  7. Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 7 中的图像 1,3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 7 中的图像 2,3 Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 7 中的图像 3,3
    • Unplug the seven connections from the power supply unit by gently pulling on them.
  8. Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 8 中的图像 1,1
    • Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
    • Four 6 mm Phillips screws
    • One 8 mm Phillips screw
  9. Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 9 中的图像 1,2 Sceptre X9 Komodo VII Power Supply Unit Replacement: 步骤 9 中的图像 2,2
    • Lift the power supply unit straight up to remove it from the back panel.
结论
Jose Carrillo
于09/26/12注册
23 声望
撰写一个指南
团队
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G56
5 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 664
