跳转到主内容
Sceptre X9 Komodo VII Liquid Crystal Display Replacement
你所需要的
  1. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Stand: 步骤 1 中的图像 1,1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 2 中的图像 1,1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Board Cover: 步骤 3 中的图像 1,1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 4 中的图像 1,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 4 中的图像 2,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 4 中的图像 3,3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 5 中的图像 1,2 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 5 中的图像 2,2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Liquid Crystal Display: 步骤 6 中的图像 1,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Liquid Crystal Display: 步骤 6 中的图像 2,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Liquid Crystal Display: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use caution when removing the connectors as they can easily break when removing.
    • Disconnect the two connectors at the top-left of the power board.
    • Disconnect the two connectors at the very bottom of the power board (pink wire).
    • Disconnect the multi-pin connector at the top of the motherboard.
    • A small flat-blade screwdriver or tweezers can be used to assist in removal of connectors.
  7. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 7 中的图像 1,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 7 中的图像 2,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 7 中的图像 3,3
    • Use a #2 Phillips to unscrew the two 4.5mm screws on each side of the back panel.
    • Carefully side the connectors through their respective openings.
    • Lif the back panel to reveal the LCD back cover.
  8. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, LCD Back Cover: 步骤 8 中的图像 1,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, LCD Back Cover: 步骤 8 中的图像 2,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, LCD Back Cover: 步骤 8 中的图像 3,3
    • Use a #2 Phillips to remove the four 6mm screws on the bezel for each side of the back cover.
    • Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed).
  9. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 9 中的图像 1,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 9 中的图像 2,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 9 中的图像 3,3
    • Use a #0 Phillips to remove the three 4.5mm screws located on the LCD back cover.
    • Lift the inner panel to remove it.
    • Disconnect the muti-pin connector on the LCD back cover by firmly pulling down on it.
  10. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 10 中的图像 1,2 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 10 中的图像 2,2
    • Use a #0 Phillips to remove the two 6mm screws on each side of the LCD cover.
    • There are tabs holding down the cover. You may have to use a bit of force to pry them open.
    • A small flat-blade screwdriver can be used to pry off LCD cover.
  11. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 11 中的图像 1,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 11 中的图像 2,3 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: 步骤 11 中的图像 3,3
    • Lift the LCD back cover to reveal the LCD screen below.
结论
另外一个人完成了本指南。
Alvin Lam
于09/26/12注册
40 声望
撰写一个指南
团队
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G56
5 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 16
总计 641
