跳转到主内容
加入维修社区 - 创建账户
Scanner Head Replacement
你所需要的
    1. Scanner Head Replacement, Remove Back Panel: 步骤 1 中的图像 1,1
      • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
      询问修复机器人
      添加评论
    2. Scanner Head Replacement, Remove Inner Back Pannel: 步骤 2 中的图像 1,2 Scanner Head Replacement, Remove Inner Back Pannel: 步骤 2 中的图像 2,2
      • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
      询问修复机器人
      添加评论
    3. Scanner Head Replacement, Remove Upper Portion: 步骤 3 中的图像 1,2 Scanner Head Replacement, Remove Upper Portion: 步骤 3 中的图像 2,2
      • Press down on the two plastic hinges to remove the upper portion of printer.
      添加评论
    4. Scanner Head Replacement, Unplug Speaker Wire: 步骤 4 中的图像 1,1
      • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
      询问修复机器人
      添加评论
    5. Scanner Head Replacement, Removing Scanner Tray: 步骤 5 中的图像 1,2 Scanner Head Replacement, Removing Scanner Tray: 步骤 5 中的图像 2,2
      • Rotate the printer so the paper tray is facing towards you.
      • Gently lift the scanner tray up and away from the printer.
      • Press the gray plastic tabs inward to release the tabs from the printer.
      询问修复机器人
      添加评论
    6. Scanner Head Replacement, Removing Scanner Tray - cont.: 步骤 6 中的图像 1,1
      • Returning to the back of the printer, remove the scanner from the back hinges.
      • With pressure applied, the scanner will detach easily.
      添加评论
    7. Scanner Head Replacement: 步骤 7 中的图像 1,1
      • Gently grasp and unplug the two white ribbon cables from the printer body.
      • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
      询问修复机器人
      添加评论
    8. Scanner Head Replacement: 步骤 8 中的图像 1,1
      • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
      • Be sure to grasp the white connector and not to pull on the wires themselves.
      询问修复机器人
      添加评论
    9. Scanner Head Replacement, Detaching the Scanner Tray: 步骤 9 中的图像 1,1
      • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
      添加评论
    1. Scanner Head Replacement, Detaching the Scanner Head: 步骤 10 中的图像 1,2 Scanner Head Replacement, Detaching the Scanner Head: 步骤 10 中的图像 2,2
      • Detach the white ribbon wire from the scanner head by pulling gently at the connection.
      询问修复机器人
      添加评论
    2. Scanner Head Replacement, Removing the Scanner Head: 步骤 11 中的图像 1,2 Scanner Head Replacement, Removing the Scanner Head: 步骤 11 中的图像 2,2
      • Lift the gray drive belt from the black tab to disconnect the drive belt from the scanner head.
      • Remove the scanner head from the scanner by gently rotating and then lifting.
      询问修复机器人
      添加评论
    3. Scanner Head Replacement, Adding New Scanner Head: 步骤 12 中的图像 1,2 Scanner Head Replacement, Adding New Scanner Head: 步骤 12 中的图像 2,2
      • Place the new scanner head in the scanner tray by fastening the drive belt into the black tab.
      • Make sure the tab on the outer portion of the gray drive belt is fastened.
      • Once the drive belt is secured, rotate the scanner head back into position.
      • Re-attach the white ribbon wire to the connection from Step 10.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 12-31, Maness Spring 2011 Cal Poly, Team 12-31, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G31
5 名成员
创作了9篇指南
2指南评论
Ok, but where do I purchase a new scanner head???
Nichelle King - 回复 分享
the step between 9 and 10 doesn't seem to make sense. it never established that the scanner head is broken...I couldn't identify where step 10 scanner head came up ...no where did it show the scanner between step 1 and step 9...Please offer an explanation...
by step 9 the scanner package had already removed...i m afraid I wont here from ifixit because the printer is about 20 years old.
winston ho - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 12,666
