跳转到主内容
Sapphire Nitro+ RX 6800 XT SE Fan Replacement
你所需要的
  1. Sapphire Nitro+ RX 6800 XT SE Fan Replacement, ARGB Fans: 步骤 1 中的图像 1,1
    • Unscrew the JIS000 screw securing the fan to the graphics card
  2. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 步骤 2 中的图像 1,1
    • Lift the fan from the top and pull away from you.
  3. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 步骤 3 中的图像 1,1
    • Clean any dust or residue present with a Q-tip damp with alcohol.
  4. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 步骤 4 中的图像 1,1
    • Flip the fan over and notice the pins on the fan and in the graphics card fan slot:
    • Fan Pins
    • Fan slot
    • Flip the fan back over keeping the same orientation and carfully insert the fan.
    • If inserted incorrectly the pins could bend or break!
  5. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 步骤 5 中的图像 1,1
    • Push the fan toward you to ensure that the pins are connected.
  6. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: 步骤 6 中的图像 1,1
    • Rescrew the JIS000 screw in the top of the fan.
    • Repeat steps 1 - 5 on the remaining fans if needed.
    • The center fan has a unique fan sicker to designate it as the middle.
结论
After assembly, the fans and RGB will work like new!
另外一个人完成了本指南。
Weston Wood
于10/23/23注册
183 声望
撰写一个指南
团队
CSU Los Angeles, Team 5-25, Kershman Fall 2023 CSU Los Angeles, Team 5-25, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S5G25
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 46
总计 399
