当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
Be careful not to rip out the ribbon connector.
To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
Gently lift ribbon out of the gate and set screen aside.
There are five screws of three different sizes which need removal.
One 4.5mm screw
Four 3.5mm screws, one on the button side
One 5.5mm screws
Slowly lift metal tray to the right.
Be careful not to bend the screw tabs or rip out the ribbon cable.
Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
