简介
This guide helps you to remove and replace the lens unit
你所需要的
Remove the five case screws with a Phillips #00 Screwdriver.
Five 3.5mm Phillips Screws
Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
There are five screws of three different sizes which need removal.
One 4.5mm screw
Four 3.5mm screws, one on the button side
One 5.5mm screws
Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
即将完成!
结论
