跳转到主内容
加入维修社区 - 创建账户
Sanyo VPC-T850 Shutter Button Replacement
你所需要的
  1. Sanyo VPC-T850 Shutter Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Shutter Button Replacement: 步骤 2 中的图像 1,1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Shutter Button Replacement: 步骤 3 中的图像 1,1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Shutter Button Replacement: 步骤 4 中的图像 1,1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: 步骤 5 中的图像 1,3 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: 步骤 5 中的图像 2,3 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: 步骤 5 中的图像 3,3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Shutter Button Replacement: 步骤 6 中的图像 1,2 Sanyo VPC-T850 Shutter Button Replacement: 步骤 6 中的图像 2,2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Shutter Button Replacement: 步骤 7 中的图像 1,1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Shutter Button Replacement: 步骤 8 中的图像 1,2 Sanyo VPC-T850 Shutter Button Replacement: 步骤 8 中的图像 2,2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Shutter Button Replacement: 步骤 9 中的图像 1,1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 Shutter Button Replacement, Shutter Button: 步骤 10 中的图像 1,1
    • Find the chrome framing located on the top of the camera.
    • The physical shutter button apparatus is directly attached to this frame.
  11. Sanyo VPC-T850 Shutter Button Replacement: 步骤 11 中的图像 1,2 Sanyo VPC-T850 Shutter Button Replacement: 步骤 11 中的图像 2,2
    • Remove the three black screws connecting the chrome frame to the camera.
    • Three screws are located toward the front, with the remaining one above the display.
  12. Sanyo VPC-T850 Shutter Button Replacement: 步骤 12 中的图像 1,1
    • Gently remove the loosened chrome frame and connected shutter button from the camera.
结论
James Robinson
于10/27/15注册
459 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 35
过去 30 天: 85
总计 536
