跳转到主内容
加入维修社区 - 创建账户
Sanyo VPC-T850 Lens Replacement
你所需要的
  1. Sanyo VPC-T850 Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Lens Replacement: 步骤 2 中的图像 1,1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Lens Replacement: 步骤 3 中的图像 1,1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Lens Replacement: 步骤 4 中的图像 1,1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Lens Replacement, Outer Casing: 步骤 5 中的图像 1,3 Sanyo VPC-T850 Lens Replacement, Outer Casing: 步骤 5 中的图像 2,3 Sanyo VPC-T850 Lens Replacement, Outer Casing: 步骤 5 中的图像 3,3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Lens Replacement: 步骤 6 中的图像 1,2 Sanyo VPC-T850 Lens Replacement: 步骤 6 中的图像 2,2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Lens Replacement: 步骤 7 中的图像 1,1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Lens Replacement: 步骤 8 中的图像 1,2 Sanyo VPC-T850 Lens Replacement: 步骤 8 中的图像 2,2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Lens Replacement: 步骤 9 中的图像 1,1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 Lens Replacement, LCD Display: 步骤 10 中的图像 1,1
    • Flip the device over to where the display is located.
    • Using your plastic opening tool, lift the display out of its metal housing.
  11. Sanyo VPC-T850 Lens Replacement: 步骤 11 中的图像 1,1
    • Locate the orange ribbon connecting the display to the camera.
    • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
  12. Sanyo VPC-T850 Lens Replacement: 步骤 12 中的图像 1,1
    • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
    • Pull slowly to avoid severing the orange ribbon from the display.
  13. Sanyo VPC-T850 Lens Replacement, Lens: 步骤 13 中的图像 1,1
    • Orient the camera so the lens is facing up.
    • Locate and remove the two screws connecting the lens to the camera.
  14. Sanyo VPC-T850 Lens Replacement: 步骤 14 中的图像 1,2 Sanyo VPC-T850 Lens Replacement: 步骤 14 中的图像 2,2
    • Flip the camera back around to the other side.
    • Remove the four black screws connecting the metal display holder to the camera.
    • You do not have to remove the three screws located near the center.
    • Gently lift the display holder to reveal the underside of the lens.
  15. Sanyo VPC-T850 Lens Replacement: 步骤 15 中的图像 1,3 Sanyo VPC-T850 Lens Replacement: 步骤 15 中的图像 2,3 Sanyo VPC-T850 Lens Replacement: 步骤 15 中的图像 3,3
    • Locate where the larger orange ribbon is plugged into the motherboard.
    • There should be a rectangular foam piece covering the part it is plugged into.
    • Using your plastic opening tool, gently lift the edge of the rectangle where the orange ribbon is connected.
  16. Sanyo VPC-T850 Lens Replacement: 步骤 16 中的图像 1,1
    • With two fingers, slowly lift the lens out of its compartment.
  17. Sanyo VPC-T850 Lens Replacement: 步骤 17 中的图像 1,1
    • With the lens between your thumb and index finger, pull to delicately slide the ribbons out of their connections.
    • The lens should be placed back into the compartment before attempting to reconnect the ribbons.
结论
另外一个人完成了本指南。
James Robinson
于10/27/15注册
459 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 78
总计 689
