跳转到主内容
简介
Instructions on how remove the LCD display.
  1. Use caution not to damage ribbon when disconnecting. The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  2. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
  3. The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
结论
另外一个人完成了本指南。
Jonathan Yau
于2010年04月11日注册
26 信誉积分
创作了4篇指南
团队
Cal Poly, Team 27-95, Amido Spring 2010 Cal Poly, Team 27-95, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G95
4 名成员
创作了4篇指南
添加评论
浏览统计数据:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
总计 3,503
