跳转到主内容
Sanyo VPC-T850 LCD Display Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Sanyo VPC-T850 LCD Display Replacement, Disconnect the Ribbon: 步骤 1 中的图像 1,2 Sanyo VPC-T850 LCD Display Replacement, Disconnect the Ribbon: 步骤 1 中的图像 2,2
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  2. Sanyo VPC-T850 LCD Display Replacement, Remove LCD Screen: 步骤 2 中的图像 1,1
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
结论
另外一个人完成了本指南。
Jonathan Yau
于04/11/10注册
26 声望
创作了4篇指南
团队
Cal Poly, Team 27-95, Amido Spring 2010 Cal Poly, Team 27-95, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G95
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 3,578
