跳转到主内容
Sanyo VPC-T850 Battery Replacement
  1. Sanyo VPC-T850 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Battery Replacement: 步骤 2 中的图像 1,1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Battery Replacement: 步骤 3 中的图像 1,1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Battery Replacement: 步骤 4 中的图像 1,1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
结论
另外一个人完成了本指南。
James Robinson
于10/27/15注册
459 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,308
