跳转到主内容
Sanyo VPC S1275 LCD Screen Replacement
你所需要的
  1. Sanyo VPC S1275 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 LCD Screen Replacement, Case: 步骤 3 中的图像 1,3 Sanyo VPC S1275 LCD Screen Replacement, Case: 步骤 3 中的图像 2,3 Sanyo VPC S1275 LCD Screen Replacement, Case: 步骤 3 中的图像 3,3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sanyo VPC S1275 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 LCD Screen Replacement: 步骤 5 中的图像 1,3 Sanyo VPC S1275 LCD Screen Replacement: 步骤 5 中的图像 2,3 Sanyo VPC S1275 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  8. Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,2 Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 2,2
    • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
    • Place the LCD screen on a non-abrasive surface.
  9. Sanyo VPC S1275 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Using the spudger lift the black flap up to release the ribbon cable.
    • The LCD screen will now be completely detached from the camera.
结论
Evan Perez
于04/15/10注册
19 声望
创作了2篇指南
团队
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G24
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 24
总计 3,321
