简介
Use this guide to access the Flash Mechanism so it can be replaced.
你所需要的
Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
Place the LCD screen on a non-abrasive surface.
Using the Phillips #00 screwdriver, remove the four screws on the outer edge of the LCD holding plate.
Using the capacitor discharge tool carefully touch each end of the capacitor discharge tool to the each terminal of the capacitor.
Click the link below for instructions on how to make the capacitor discharge tool: Constructing a Capacitor Discharge Tool
Keep the wires connected to the capacitor terminals for 2 minutes to completely discharge the capacitor.
The camera should be completely safe to handle now.
Touch the soldering iron tip to the solder in the upper right corner connecting the logic board to the battery lead.
Pull the battery lead out of the slot in the logic board. This must be done immeadiately after the solder melts.
Repeat for the solder to the left.
The logic board will now be completely free from the camera.
