跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Sanyo VPC S1275 Case Replacement
你所需要的
  1. Sanyo VPC S1275 Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 Case Replacement: 步骤 2 中的图像 1,1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 Case Replacement, Case: 步骤 3 中的图像 1,3 Sanyo VPC S1275 Case Replacement, Case: 步骤 3 中的图像 2,3 Sanyo VPC S1275 Case Replacement, Case: 步骤 3 中的图像 3,3
    • Unscrew 6 Phillips screws using the #00 Phillips screwdriver.
    • Two screws are on the left side of the camera.
    • Two screws are on the right side of the camera.
    • Two screws are on the bottom of the camera.
  4. Sanyo VPC S1275 Case Replacement: 步骤 4 中的图像 1,2 Sanyo VPC S1275 Case Replacement: 步骤 4 中的图像 2,2
    • Open battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the 4 mm phillips screw on the bottom right using the #00 phillips screwdriver.
  5. Sanyo VPC S1275 Case Replacement: 步骤 5 中的图像 1,3 Sanyo VPC S1275 Case Replacement: 步骤 5 中的图像 2,3 Sanyo VPC S1275 Case Replacement: 步骤 5 中的图像 3,3
    • Insert spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 Case Replacement: 步骤 6 中的图像 1,1
    • This step is only needed for the case and logic board replacement
    • Using the #00 phillips screwdriver remove the screw attached to the front casing in the top left corner. Front case should easily separate.
  7. Sanyo VPC S1275 Case Replacement: 步骤 7 中的图像 1,1
    • This step is only needed for the case replacement.
    • Using the #00 phillips screwdriver remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
结论
团队
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G24
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,976
