跳转到主内容
Sanyo SCP-8100 Keypad Replacement
你所需要的
  1. Sanyo SCP-8100 Keypad Replacement, Battery: 步骤 1 中的图像 1,3 Sanyo SCP-8100 Keypad Replacement, Battery: 步骤 1 中的图像 2,3 Sanyo SCP-8100 Keypad Replacement, Battery: 步骤 1 中的图像 3,3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Sanyo SCP-8100 Keypad Replacement, Back Panel: 步骤 2 中的图像 1,2 Sanyo SCP-8100 Keypad Replacement, Back Panel: 步骤 2 中的图像 2,2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Sanyo SCP-8100 Keypad Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Sanyo SCP-8100 Keypad Replacement: 步骤 4 中的图像 1,2 Sanyo SCP-8100 Keypad Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Sanyo SCP-8100 Keypad Replacement: 步骤 5 中的图像 1,3 Sanyo SCP-8100 Keypad Replacement: 步骤 5 中的图像 2,3 Sanyo SCP-8100 Keypad Replacement: 步骤 5 中的图像 3,3
    • While removing the back panel, take out the rubber cover on each side.
  6. Sanyo SCP-8100 Keypad Replacement, Keypad: 步骤 6 中的图像 1,2 Sanyo SCP-8100 Keypad Replacement, Keypad: 步骤 6 中的图像 2,2
    • Pull the volume and camera buttons off from the side of the phone.
  7. Sanyo SCP-8100 Keypad Replacement: 步骤 7 中的图像 1,2 Sanyo SCP-8100 Keypad Replacement: 步骤 7 中的图像 2,2
    • Pull the gray frame covering the charging port from the bottom of the phone.
  8. Sanyo SCP-8100 Keypad Replacement: 步骤 8 中的图像 1,2 Sanyo SCP-8100 Keypad Replacement: 步骤 8 中的图像 2,2
    • Use the opening tool to lift the motherboard up from the phone.
    • Be careful and pry the motherboard off slowly. The motherboard will be attached to the phone at the top by a metal ribbon.
  9. Sanyo SCP-8100 Keypad Replacement: 步骤 9 中的图像 1,3 Sanyo SCP-8100 Keypad Replacement: 步骤 9 中的图像 2,3 Sanyo SCP-8100 Keypad Replacement: 步骤 9 中的图像 3,3
    • Flip open the phone, exposing the keypad.
    • Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
    • Pull the keypad out of the phone.
结论
另外一个人完成了本指南。
Irenz Afable
于04/15/13注册
57 声望
创作了3篇指南
团队
Cal Poly, Team 10-41, Amido Spring 2013 Cal Poly, Team 10-41, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G41
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 378
