跳转到主内容
Sanyo S1414 LCD Replacement
你所需要的
  1. Sanyo S1414 LCD Replacement, LCD: 步骤 1 中的图像 1,3 Sanyo S1414 LCD Replacement, LCD: 步骤 1 中的图像 2,3 Sanyo S1414 LCD Replacement, LCD: 步骤 1 中的图像 3,3
    • Remove the batteries and the memory card if so equipped.
    • Remove the two Phillips screws on the right.
    • Remove the four Phillips screws on the bottom.
  2. Sanyo S1414 LCD Replacement: 步骤 2 中的图像 1,3 Sanyo S1414 LCD Replacement: 步骤 2 中的图像 2,3 Sanyo S1414 LCD Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws on the left.
    • With all the screws removed, the case will split easy. No tool is required.
    • Front and back case come off at the same time. the silver midframe that houses the top buttons, remains on the camera.
  3. Sanyo S1414 LCD Replacement: 步骤 3 中的图像 1,3 Sanyo S1414 LCD Replacement: 步骤 3 中的图像 2,3 Sanyo S1414 LCD Replacement: 步骤 3 中的图像 3,3
    • The LCD ribbon cable is folded under the holder. Do not try to remove the LCD yet. It will tear the ribbon cable.
    • Fold the LCD way from the holder. Remove the four screws that secure the holder to the logic board.
    • With the LCD holder out of the way, you can now open the ribbon cable connector. Use your fingernails to flip the white clasp away from the ribbon cable side. This will disconnect the cable. Remove the LCD and replace with the new one.
结论
2等其他人完成本指南。
oldturkey03
于09/29/10注册
782,216 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了537篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 986
