跳转到主内容
Sanyo Katana Screen Replacement
你所需要的
  1. Sanyo Katana Screen Replacement, Screen Protector: 步骤 1 中的图像 1,2 Sanyo Katana Screen Replacement, Screen Protector: 步骤 1 中的图像 2,2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Screen Replacement: 步骤 2 中的图像 1,2 Sanyo Katana Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Screen Replacement: 步骤 3 中的图像 1,2 Sanyo Katana Screen Replacement: 步骤 3 中的图像 2,2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Screen Replacement, Front Case: 步骤 4 中的图像 1,3 Sanyo Katana Screen Replacement, Front Case: 步骤 4 中的图像 2,3 Sanyo Katana Screen Replacement, Front Case: 步骤 4 中的图像 3,3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Screen Replacement, Screen: 步骤 5 中的图像 1,2 Sanyo Katana Screen Replacement, Screen: 步骤 5 中的图像 2,2
    • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
    • Use fingers to remove the strip from the device.
  6. Sanyo Katana Screen Replacement: 步骤 6 中的图像 1,3 Sanyo Katana Screen Replacement: 步骤 6 中的图像 2,3 Sanyo Katana Screen Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
  7. Sanyo Katana Screen Replacement: 步骤 7 中的图像 1,2 Sanyo Katana Screen Replacement: 步骤 7 中的图像 2,2
    • Use the flat edge of the spudger to detach the screen from the phone casing.
    • Pull the screen up and away from the case.
结论
Aliceann
于03/11/13注册
49 声望
撰写一个指南
团队
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G1
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 614
