跳转到主内容
Sanyo Katana Motherboard Replacement
你所需要的
  1. Sanyo Katana Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Sanyo Katana Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Sanyo Katana Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
    • While holding down the button, pull cover off with other hand.
  2. Sanyo Katana Motherboard Replacement: 步骤 2 中的图像 1,3 Sanyo Katana Motherboard Replacement: 步骤 2 中的图像 2,3 Sanyo Katana Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use fingers to grip the battery and remove it from the phone.
  3. Sanyo Katana Motherboard Replacement, Back Casing: 步骤 3 中的图像 1,1
    • Using a spudger, remove the four rubber coverings on the lower back plate.
  4. Sanyo Katana Motherboard Replacement: 步骤 4 中的图像 1,3 Sanyo Katana Motherboard Replacement: 步骤 4 中的图像 2,3 Sanyo Katana Motherboard Replacement: 步骤 4 中的图像 3,3
    • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
  5. Sanyo Katana Motherboard Replacement: 步骤 5 中的图像 1,3 Sanyo Katana Motherboard Replacement: 步骤 5 中的图像 2,3 Sanyo Katana Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
  6. Sanyo Katana Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Sanyo Katana Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
  7. Sanyo Katana Motherboard Replacement: 步骤 7 中的图像 1,3 Sanyo Katana Motherboard Replacement: 步骤 7 中的图像 2,3 Sanyo Katana Motherboard Replacement: 步骤 7 中的图像 3,3
    • For the following steps, the phone is shown closed to make manipulating the parts easier.
    • Using a spudger, remove the thin aluminum plate to access the upper motherboard.
    • This will most likely be difficult to pry off and will take a considerable amount of force. Stay clear of the piece to avoid injury when it comes free of the device.
  8. Sanyo Katana Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use the flat end of the spudger to remove two ribbon cables from the back of the motherboard.
  9. Sanyo Katana Motherboard Replacement: 步骤 9 中的图像 1,3 Sanyo Katana Motherboard Replacement: 步骤 9 中的图像 2,3 Sanyo Katana Motherboard Replacement: 步骤 9 中的图像 3,3
    • Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys.
    • Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
结论
另外一个人完成了本指南。
StephenYH
于03/11/13注册
20 声望
创作了3篇指南
团队
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G1
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 515
