跳转到主内容
Sanyo Katana Eclipse X Battery Replacement
你所需要的
  1. Sanyo Katana Eclipse X Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Sanyo Katana Eclipse X Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Sanyo Katana Eclipse X Battery Replacement: 步骤 2 中的图像 1,1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Sanyo Katana Eclipse X Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Refer to photo illustrations.
    • Using your thumb, apply gentle pressure to the battery until it clicks into place.
  4. Sanyo Katana Eclipse X Battery Replacement: 步骤 4 中的图像 1,1
    • Take the phone’s back casing and set it over the battery.
    • Apply gentle pressure, pushing towards the top of the phone until your hear a click.
结论
Thomas Scaggs
于10/15/12注册
209 声望
创作了2篇指南
团队
University of Maine, Team 1-3, Diaz Fall 2012 University of Maine, Team 1-3, Diaz Fall 2012 的会员
UMAINE-DIAZ-F12S1G3
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 473
