跳转到主内容
Sanyo Katana Camera Replacement
你所需要的
  1. Sanyo Katana Camera Replacement, Screen Protector: 步骤 1 中的图像 1,2 Sanyo Katana Camera Replacement, Screen Protector: 步骤 1 中的图像 2,2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Camera Replacement: 步骤 2 中的图像 1,2 Sanyo Katana Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Camera Replacement: 步骤 3 中的图像 1,2 Sanyo Katana Camera Replacement: 步骤 3 中的图像 2,2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Camera Replacement, Front Case: 步骤 4 中的图像 1,3 Sanyo Katana Camera Replacement, Front Case: 步骤 4 中的图像 2,3 Sanyo Katana Camera Replacement, Front Case: 步骤 4 中的图像 3,3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Camera Replacement, Camera: 步骤 5 中的图像 1,3 Sanyo Katana Camera Replacement, Camera: 步骤 5 中的图像 2,3 Sanyo Katana Camera Replacement, Camera: 步骤 5 中的图像 3,3
    • Use a Tri-wing Y0 screwdriver to remove the 4.4mm screw.
    • Use fingers to remove the strip.
  6. Sanyo Katana Camera Replacement: 步骤 6 中的图像 1,3 Sanyo Katana Camera Replacement: 步骤 6 中的图像 2,3 Sanyo Katana Camera Replacement: 步骤 6 中的图像 3,3
    • Detach the ribbon connections underneath the green connector strip and remove them from the device. This will reveal the camera.
  7. Sanyo Katana Camera Replacement: 步骤 7 中的图像 1,3 Sanyo Katana Camera Replacement: 步骤 7 中的图像 2,3 Sanyo Katana Camera Replacement: 步骤 7 中的图像 3,3
    • Using a spudger, remove the ribbon connection of the camera from the adhesive that attaches it to the device.
    • Grab the camera using fingers and remove it from the phone case.
结论
Preston
于03/11/13注册
216 声望
创作了5篇指南
团队
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G1
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 321
