当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Before disassembling the device, make sure it is powered off.
Remove the four 1.5mm screws on the back of the device.
Using a plastic opening tool, lift the metal backing from the front of the device.
Pull the rear panel off of the Sansa e260R.
Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Remove the four 1.5mm screws on the inner casing of the device.
These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
Flip the device so that the front is facing you.
Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
Pull the front cover away from the rest of the device.
取消:我没有完成这个指南。
与5其他贡献者
于01/20/12注册
111 声望
创作了3篇指南
徽章: 8
+ 5更多徽章
CPSU-MANESS-W12S8G15
5 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 1,977
