跳转到主内容
Sanitaire SC684 front wheel replacement
你所需要的
  1. Sanitaire SC684 front wheel replacement, Front Wheels: 步骤 1 中的图像 1,1
    • Be sure to unplug the vacuum before disassembling it to prevent electric shock.
    • Lay the vacuum on its side.
    • Using a Phillips #1 screwdriver, unscrew the screws located behind the front wheels on the underside of the vacuum.
  2. Sanitaire SC684 front wheel replacement: 步骤 2 中的图像 1,2 Sanitaire SC684 front wheel replacement: 步骤 2 中的图像 2,2
    • Stand the vacuum upright, unscrew the single screw located on the center dial using a Torx T20 screwdriver and remove the dial form the vacuum body.
  3. Sanitaire SC684 front wheel replacement: 步骤 3 中的图像 1,1
    • Lift the top cover off of the vacuum.
  4. Sanitaire SC684 front wheel replacement: 步骤 4 中的图像 1,1
    • Identify the two gray metal plates at the front of the vacuum.
    • Using the T20 Torx screwdriver, remove the four screws on the smaller gray plate holding the larger gray metal plates.
  5. Sanitaire SC684 front wheel replacement: 步骤 5 中的图像 1,2 Sanitaire SC684 front wheel replacement: 步骤 5 中的图像 2,2
    • Remove the small metal plate with the black bolt in the center and the larger gray plate from both sides.
  6. Sanitaire SC684 front wheel replacement: 步骤 6 中的图像 1,2 Sanitaire SC684 front wheel replacement: 步骤 6 中的图像 2,2
    • Pull out the silver bar that holds the two wheels to the vacuum body and detach the small spring from the vacuum body.
  7. Sanitaire SC684 front wheel replacement: 步骤 7 中的图像 1,2 Sanitaire SC684 front wheel replacement: 步骤 7 中的图像 2,2
    • Remove the wheel from the side with the spring by pulling it off the axel and slide off the spring, as it will be needed for the replacement front wheels.
结论
Caycie Pascual
于09/26/12注册
1 声望
创作了4篇指南
团队
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G58
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,066
