工具
无需工具。
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  4. Lift off the metal plate by pulling it towards you.
    • Lift off the metal plate by pulling it towards you.
  5. Identify the belt and brush roller.
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
  6. Slide the belt off of the circular knob.
    • Slide the belt off of the circular knob.
  7. Pull brush roller out and detach the belt off the brush roller. Pull brush roller out and detach the belt off the brush roller.
    • Pull brush roller out and detach the belt off the brush roller.
结论
Caycie Pascual
于2012年09月26日注册
1 信誉积分
创作了5篇指南
团队
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G58
5 名成员
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 836
