当前版本的文档还未经巡查,您可以查看最新的已查核版本。
拆解
这个拆解是不是维修指南。 要维修你的的Sandisk Sansa m230 Series mp3 player,请使用我们的维修手册。
这个步骤还没有翻译 帮忙翻译一下
Remove the battery compartment cover.
Remove the battery.
Locate and remove the screw next to the battery compartment lid.
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
Be careful when prying apart the pegs: they are made of plastic and may break.
The battery contact springs may prevent the case from separating.
Push the battery contact springs down through the hole in the case.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
You now have access to all components found on the inside of the device!
与11其他贡献者
于11/05/13注册
638 声望
创作了6篇指南
徽章: 7
+ 4更多徽章
UMASSD-SHASTANY-F13S1G8
3 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 27
总计 2,746
