跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Sandisk Sansa m230 Series mp3 player,请使用我们的维修手册
  1. Sandisk Sansa m230 Series mp3 player Teardown, Sandisk Sansa m230 Series mp3 player Teardown: 步骤 1 中的图像 1,1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Teardown: 步骤 2 中的图像 1,1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Teardown: 步骤 3 中的图像 1,1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Teardown: 步骤 4 中的图像 1,1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Teardown: 步骤 5 中的图像 1,1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Teardown: 步骤 6 中的图像 1,1
    • You now have access to all components found on the inside of the device!
James Thorne
于11/05/13注册
638 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-8, Shastany Fall 2013 UMass Dartmouth, Team 1-8, Shastany Fall 2013 的会员
UMASSD-SHASTANY-F13S1G8
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 27
总计 2,747
