跳转到主内容
Sandisk Sansa m230 Series mp3 player Microphone Replacement
你所需要的
  1. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Sandisk Sansa m230 Series mp3 player Teardown: 步骤 1 中的图像 1,1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 2 中的图像 1,1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 3 中的图像 1,1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 4 中的图像 1,1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 5 中的图像 1,1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 6 中的图像 1,1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Microphone: 步骤 7 中的图像 1,1
    • Locate microphone on motherboard.
  8. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 8 中的图像 1,1
    • Find where microphone is connected to motherboard via solder.
  9. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 9 中的图像 1,2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 9 中的图像 2,2
    • Use the soldering iron to liquefy the solder connecting the microphone to the motherboard.
  10. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 10 中的图像 1,1
    • The solder and soldering iron will be very hot at this time. Do not touch unless wearing protective gloves as you will be burnt.
    • When not in use, be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
  11. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 11 中的图像 1,2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 11 中的图像 2,2
    • Remove the faulty microphone as you heat and melt the soldering points.
  12. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 12 中的图像 1,1
    • Replace the faulty microphone with a new one in working order.
  13. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 13 中的图像 1,2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: 步骤 13 中的图像 2,2
    • With the new microphone in place, use the soldering iron and solder to create a stable connection between the motherboard and microphone.
    • Give the new solder time to cool and harden.
结论
James Thorne
于11/05/13注册
638 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-8, Shastany Fall 2013 UMass Dartmouth, Team 1-8, Shastany Fall 2013 的会员
UMASSD-SHASTANY-F13S1G8
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 496
