跳转到主内容
Sandal Brooch Replacement
你所需要的
  1. Sandal Brooch Replacement, Brooch: 步骤 1 中的图像 1,3 Sandal Brooch Replacement, Brooch: 步骤 1 中的图像 2,3 Sandal Brooch Replacement, Brooch: 步骤 1 中的图像 3,3
    • Unwind about 10" of thread. Cut and thread through the needle. Tie a double knot at the end of the thread.
  2. Sandal Brooch Replacement: 步骤 2 中的图像 1,2 Sandal Brooch Replacement: 步骤 2 中的图像 2,2
    • The threads and empty holes show exactly where to attach the shoe ornament.
    • Cut off the old threads.
  3. Sandal Brooch Replacement: 步骤 3 中的图像 1,2 Sandal Brooch Replacement: 步骤 3 中的图像 2,2
    • Start the threaded needle on the upper side of the sandal.
    • The ornament will hide the knot.
    • If pushing the needle through the sandal strap is difficult, you might try turning the sandal at an angle and using your flat surface as a pressing point.
  4. Sandal Brooch Replacement: 步骤 4 中的图像 1,1
    • Pull the thread through the ornament's opening.
    • Be careful—needles are sharp!
  5. Sandal Brooch Replacement: 步骤 5 中的图像 1,3 Sandal Brooch Replacement: 步骤 5 中的图像 2,3 Sandal Brooch Replacement: 步骤 5 中的图像 3,3
    • Pull the thread down and through the sandal straps.
    • Repeat the process, catching the ornament in a variety of places to anchor several sides.
  6. Sandal Brooch Replacement: 步骤 6 中的图像 1,2 Sandal Brooch Replacement: 步骤 6 中的图像 2,2
    • Pull the thread so that the ornament is tight against the sandal.
    • Remember to beware of that sharp needle!
  7. Sandal Brooch Replacement: 步骤 7 中的图像 1,1
    • Run the needle back through the sandal strap, then tie a knot at the base of the thread.
    • Double the knot before using your scissors to cut the thread.
    • Cut the thread just above the knot.
    • Be careful—scissors are sharp.
  8. Sandal Brooch Replacement: 步骤 8 中的图像 1,1
    • Completed sandal—ready to wear!
结论
Enjoy wearing the sandals!
KaC
于08/27/23注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 161
