跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
SanDisk Sansa C250 Rear Case Cover Replacement
你所需要的
  1. SanDisk Sansa C250 Rear Case Cover Replacement, Battery Cover: 步骤 1 中的图像 1,1
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Rear Case Cover Replacement: 步骤 2 中的图像 1,1
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Rear Case Cover Replacement, Battery: 步骤 3 中的图像 1,1
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Rear Case Cover Replacement: 步骤 4 中的图像 1,1
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Rear Case Cover Replacement: 步骤 5 中的图像 1,1
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Rear Case Cover Replacement, Rear Case Cover: 步骤 6 中的图像 1,1
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Rear Case Cover Replacement: 步骤 7 中的图像 1,1
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Rear Case Cover Replacement: 步骤 8 中的图像 1,1
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Rear Case Cover Replacement: 步骤 9 中的图像 1,1
    • The rear case cover can now be separated from the device.
结论
Nicolas Coffey
于01/27/12注册
43 声望
创作了4篇指南
团队
Cal Poly, Team 3-30, Amido Winter 2012 Cal Poly, Team 3-30, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G30
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 825
